-   General Tech (https://camaroforums.com/forum/general-tech-5/)
-   -   OBD 1 question (https://camaroforums.com/forum/general-tech-5/obd-1-question-34123/)
kyleag89 Dec 23, 2008 05:08 PM
OBD 1 question
My car will flash code 12 4x and then code 30 3x...There is no code 30 in the diagnostic manuel... What does this mean? I replaced my distributor cap and rotor and started the car and its runs better but now SES light on.
Saint_Ali Dec 23, 2008 07:40 PM
RE: OBD 1 question
if you are reffering to your 91, it is not OBD1, OBD1 wasnt available on Fbodies until 94.Code 12 is just saying the system is working when you scan it.Are you sure it was code 30 ?
Gorn Dec 23, 2008 07:59 PM
RE: OBD 1 question
OK i will bit, How does the system blink a zero? Are you using some sort of code reader? Normally all codes including 12 are blinked 3 times. Since themanual repair system required you to count blinks to get the code there are no codes with a zero in it.
Saint_Ali Dec 23, 2008 08:50 PM
RE: OBD 1 question
rofl yeah, i never thought of that, but i know there is no code 30, and there is no single digit codes so you must have counted wrong
kyleag89 Dec 23, 2008 10:57 PM
RE: OBD 1 question
Well after the car flashes code 12 it flashes 3x one after another... I figured the ses light flashing 3x would mean 3 and then nothing so 0.
Saint_Ali Dec 23, 2008 11:24 PM
RE: OBD 1 question
are you sure its not 33 ?
when it flashes are you sure there isnt any pauses you missed ?
kyleag89 Dec 24, 2008 11:46 AM
RE: OBD 1 question
33 Is a MAF sensor... Ill check it out
Gorn Dec 25, 2008 12:15 AM
RE: OBD 1 question
If you are talking the TBI injection in your sig then the 33 in MAP sensor error. Only the TPI had the MAF sensor.
kyleag89 Dec 26, 2008 01:55 PM
RE: OBD 1 question
Ok I figured it out.. I have a code 32 and 33...
32Fault in barometric pressure sensor circuit OR Fault in exhaust gas recirculation valve diagnostic switch OR Fault in electronic vacuum regulator valve
What does this mean? What should I look at?
Also 33- Map sensor High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
Gorn Dec 26, 2008 04:16 PM
RE: OBD 1 question
If you get a repair manual for your years it will give a a step by step on how to diagnose your code. Normally the processis to check signal from the computer check resistance across sensor then with a scan tool look at what the input into the computer looks like.
IF
32 is a fault in the barmetricsensor
33 is a problem with the Map sensor
If I remember right they are the same sensor. Back in the day if I would have gotten those codes I would have just hooked up a known good Map sensor before I even started with the step by step stuff, About 70% of the time that fixed it.
