Loose Steering Column
I have a 98 Camaro v6 5spd. The steering column is loose and it won't pass inspection. I think it is a very common problem that i have researched about Chevy’s; something to do with the bolts inside the column that need to be tightened. Is there a write up on how to do this fix on the camaros, maybe something with pics. Or anyone in the central VA area that have done it and could help. Thanks
RE: Loose Steering Column
Its common on the early columns but I don't know about the square ones. They are built different but could be where the aluminum housing bolts to the steel tube. Have not seen them come loose yet.
