if you use dex-cool read this
#21
RE: if you use dex-cool read this
ORIGINAL: t4nk
yeah I was about to post a topic asking if someone has an idea what this could be.. but I've got a problem.. I've got some brownish red crap in my fluid, and it looks like peices of silicon.. and a leak somewhere! i have to top it off every couple of days, it starts running at 210°+ after a couple days. Does this sound related to Dex-Cool?
#22
i agree i would not think that dex-cool would make it leak... but the WHOLE cooling system was replaced a little over a year ago.. I don't think I should have rust & silicon flowing thru the system THIS soon..
#23
That does seem odd. Maybe it was not flushed proper and there was contaminents in the system. As you can read in a link in one of the posts that dex does not play well with them.
Good luck on fixing it
#24
I have a 97 Blazer with all the same problems. The rusty sludge, intake gasket, heater core, thermastat and so on. I fixed it all with flushing out the dex-cool and torqueing the intake bolts, along with some aluma seal and some jb weld. This fix was only gona be a 2 week deal till I bought a new ride. That was 30,000 miles ago. Not bad for a $20 fix. At 147,000 miles who can say its the dex-cool, I think it's more of a time issue. Also this is an aluminum block/heads motor, so is the rusty color rust or just the dex-cool? If it was rust the block would be long gone by now.
#25
#26
ORIGINAL: Alih
Dex-Cool coolant has caused rusty sludge to develop in cooling systems
#28
Another issue with dex. I was running Valvoline synthetic in my wife's Montana V6. When the intake gasket started to leak the anti-freeze went to the crankcase. The resulting mixture turned to jelly, after taking off the filter nothing would run out when turned upside down. It took four engine flushes just to get oil to flow to the rockers after that.
