i got a question hopefully one of you motorheads could help me with
im in the middle of trading for a full size 1981 chevy scottsdale pickup4x4 3/4 ton with a 350 4bm and a 400 turbo transmission. the guy im tradin with said that when he drove the truck home it was alright shifted smoothly and everything. but after he parked it , he intended to restore it and it sat for about a year or a little less. now he said when he puts it in reverse, and 1st it just wants to hesitate to move. i know the guy and he doesnt hot-rod things at all, He thinks something might have got caught in the jets inside the tranny causing it to do that, and figures it could be fixed with a simple flushing of the transmission. what do u guys think.
RE: i got a question hopefully one of you motorheads could help me with
Check the fluid..My camaro sat for a year and did the same thing, but was low on fluid..I added some and she was fine again.....but I would check it first. With a little new fluid and a few times going into first and rev and it should be fine..if not then you may have problems.
ya i would say let him flush and fill it sounds like it is low on the fluid, and if it has been sitting for that long a good flush and fill is not a bad ideal clean it out, but also just to make sure by some cheap atf fill it up and make sure..
I agree with 74454. Just check and add fluid. Might not need a full flush just yet.
edit: Excersize the gears before really getting on the tranny.
ORIGINAL: 91camaro305rs
the breaks arent locked up are they
UPDATE
i went out to where the truck is with 4 quarts of transmission fluid for it . i went to check the fluid it had in it , and guess what? It was BONE DRY. i put the 4 quarts and drove it for about 5minutes, and it drove like a dream. cant wait to go muddin.
