-   General Tech (https://camaroforums.com/forum/general-tech-5/)
-   -   I CAN SEE MY TORQUE CONVERTER!!!! (https://camaroforums.com/forum/general-tech-5/i-can-see-my-torque-converter-9832/)
microkid Jan 10, 2007 10:54 PM
and the fly wheel too. its on my 86 z28 tpi, with a brand new 700r4. tranny fluid seams to be fine (light amount past the full line, bright red). i noticed it because i was inspecting my lights and heard a click noise and though maybe it was my exhaust, looked underneth and saw the bright blue converter spinning. its on the passenger side, and is an opening about half an inch to the top, and gets narrow to a close at the bottom. what can i do to fix this? is there a rubber seal, a metal shield, or is my tranny about to fall off?
shnormo Jan 10, 2007 10:58 PM
RE: I CAN SEE MY TORQUE CONVERTER!!!!
Usually there is a transmission dust shield.
79maroman Jan 11, 2007 12:55 AM
is the bolt holding the dust shield coming loose? gone? sounds like you have a shield, but that it is coming off at one point. if you have a digital camera, take a quick snap-shot, and we'll be able to tell you.
MadMikeZ28 Jan 11, 2007 02:43 AM
The tranny case around the converter and flywheel is at an angle from the tranny pan to the bottom of the block. There should be a plastic cover that fills in the rest of that area.
microkid Jan 11, 2007 11:28 PM
i will take a look tomarrow and if i cant fix it, ill take a pic. i think my car spends more time on jacks than it has been driven
blackz87 Jan 11, 2007 11:31 PM
Replacements cost about $25
microkid Jan 14, 2007 01:57 PM
where can i get a replacement? i checked on jegs with no luck.
z28pete Jan 14, 2007 02:15 PM
Chevy dealer, they have all the parts.
blackz87 Jan 14, 2007 03:15 PM
Any good Transmission Shop, it is a standard item for all 700R4 autos.
microkid Jan 15, 2007 06:25 PM
i finally got chance to get underneth and look. its just missing a bolt from the plastic peice. anyone know what size it should be?
