Humming noise in car wile driving
Hello all, I have a 2002 camaro 3.8 5 speed with 56000 miles one it. Wile I am driving down the road, thier is a humming noise in the car. The tone gets "higher" as I increase speed and gets "lower" as I decrease speed. Originaly I thought it might be the tires?? I don't know if it is comming from the front or rear. I have not checked the rear diff fluid. Your help would be aprieciated
Does it sound like this......hmmmmmmmmmmmmm? Is it a "whiney" sort of hum?
Could be your rear gears, either from worn bearings in the differential, or worn outer wheel bearings putting an improper load on the ring & pinion gears. You really need to know for sure what area the hum is coming from.
