how to progrm remote???
[sm=hail.gif]on my 95 camaro.... please very detailed instructions
this "port" they keep talking about... is it the obd port or.......................? 1. Turn the ingition switch to off 2. Jumper program connector terminal 8 and 4 (look about where your right knee is, assuming a normal driving position, for a little plug. It has 8 holes on the top, 8 holes on the bottom- put the end of a paper clip in the 8th top hole, then put the other end of the paper clip in the 4th top hole). The door locks will lock and unlock in approximately two seconds 3. Press lock and unlock button on one of your remotes. Door locks will lock and unlock in approximately ten seconds. The RFA Module is now programmed for the first transmitter. 4. Repeat step 3 using other transmitter if you have more than one remote 5. Disconnect jumper from program connector. Note: This is for a 1995 model. Another year model might be different. |
RE: how to progrm remote???
Thats what it sounds like.
1 Attachment(s)
I saw the AU0 code in my glove box, so I just tried the paperclip test on my '95 Camaro and my doors locked & unlocked - hooray! Just bought my remote on eBay :)
Attachment 38679 |
