How the heck to remove these screws?
Old Nov 2, 2008 | 05:51 PM
vambercidw's Avatar
Default How the heck to remove these screws?
Question guys ... need some input here on how to remove these screws. These are the screws that hold the lower hinge to the door. They are rusted on .. hv put the PB penetrating oil on .. no luck. Regular screwdriver is not doing a dayam thing. I have tried a hand impact ... still doesn't work. Drill them out?
[IMG]local://upfiles/14955/41E1F474941241DBB246DD06AC8A586B.jpg[/IMG]
Old Nov 2, 2008 | 05:59 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: How the heck to remove these screws?
if all else fails just drill them out and retap the holes. tapping isnt that bad at all, the drilling part is the pain in the butt. I would give it a couple days with penetrating oil.
heat is another thing you can try for problematic screws. My exhaust had a panel rusted on last spring and I had a shop heat it and loosen it for me for like 20 bucks.
Old Nov 2, 2008 | 07:12 PM
MadMikeZ28's Avatar
Those kind of bolts I would put a phillips screwdriver socket on an air impact and the hammer action of it would usualy break them loose. Maybe since your door is off if you have a way to haul it take it to a shop and see if they will use an impact on it for you.
Old Nov 2, 2008 | 07:35 PM
t9ojetpilot's Avatar
[:@] if these are nicely rusted they will be a ***** to remove. if youve already tried an impact driver make sure you used the proper bit (a #3 phillips i believe) heat on the backside is another option. failing these put a nut over the top and weld down the center into the screw this gives you a nice large gripping surface. this is by no means a cure all but its the best if the screw is gonna come out at all. if its just too rusted and become one with the surrounding metal the drilling or grinding of the screw head may be your only options kurt
Old Nov 2, 2008 | 07:52 PM
Ninja Administrator
^^^ actually, thats how the shop got mine loose, by welding peices to the bolts and cranking on them.
i still think a better use of his time is to just get a drill and retap them.
Old Nov 2, 2008 | 09:17 PM
vambercidw's Avatar
Want to thank everyone for the suggestions. Out of the 6 screws .. i have 2 off so far. Here's what i did for now. I took the end of the hand impact with the phillips head bit and put it on my air impact since both are 1/2 inch sockets. The other 4 screws still aren't coming out ... they'restarting to strip. So i'll try the heat trick and if that doesn't work then i'll try the other couple suggestions and drill them out or weld on a nut. I don't hva welder but the guy down the street does.
Thanks again ya'll. I'll let you know what works on the other 4.
Old Nov 13, 2008 | 01:11 PM
vambercidw's Avatar
Update .. got the last couple screws out by welding on a nut ... then they came out like butter. Prolly just the action of being heated up did the trick. All are out. Now I can proceed with media blasting.
Old Nov 13, 2008 | 11:39 PM
bowtieguy's Avatar
July 2009 ROTM
suggestion/////dont put those kind of screws back in there.use a 3/8 bolt with a head and a washer.painted to match or nice shiney ones ,nobody will ever know
vanquishfist
Jan 1, 2013 11:11 PM
1971BB427
Feb 26, 2011 05:17 PM
bayman88
Dec 13, 2009 05:56 PM
bashgod
May 4, 2009 10:30 AM
Paradox86
Jul 20, 2007 01:46 PM
