help w/ headlight 97 Camaro
Old Sep 15, 2005 | 01:11 PM
jofishr's Avatar
Default help w/ headlight 97 Camaro
My headlights won't come on either automatically or with the headlight switch
But when I pull the lever my brights will work
Old Sep 18, 2005 | 09:06 AM
02StanGT's Avatar
Default RE: help w/ headlight 97 Camaro
Either both low beams are out, or you need to replace the fuse for the low beams.
Old Sep 18, 2005 | 01:26 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
either your low beams are blown, or you have a bad relay
Old Oct 26, 2005 | 08:29 PM
jofishr's Avatar
Both my bulbs were out (bad)
Can you believe they both wen't out at the same time?
One was less than a year old
Put the new one's in about 1 month ago and still working
Old Oct 27, 2005 | 10:34 AM
02StanGT's Avatar
I can believe it. I was having to replace a light quite often, on mine. Those lights are somewhat pricey too.
Old Oct 28, 2005 | 05:01 PM
Hisss04Cobra's Avatar
In my 4runner one of light worked on bright and low, but the other one only work on bright, I had to replace both lights...
Old Oct 29, 2005 | 01:36 AM
carlsbadlt1's Avatar
Same thing happened to me last month... Both of them went out the same night. I checked the fuse, exchanged the relay... still nothing. Bought two new bulbs and they came right on.
Red-Cricket
Jan 21, 2011 08:47 PM
shawnathan
Jan 25, 2009 05:22 PM
mrunowich
Jul 31, 2008 09:24 PM
Foskey
Aug 17, 2007 08:15 PM
