having weird problems need help
I let my friend use my car for a month and I got it back and it has a ton of problems it was just stalling about every ten minutes but I found a faulty connector at the coil and replaced it but now it idles rough in the mornings and after it heats up to operating temp the low coolent light comes on I have check the coolent level and it is good. It also has been acting slugish like it wants to die and if I get on it it back fires a little. mods msd opti, msd blaster coil, #305 comp cam, bbk shorts, removed egr, lt4 knok module, 58mm throtle body, intake.
