fuel pump NEED help!!!
hey i am having problems with my fuel pump.... i have a volt meter and i am getting 8.65 volts??? should it not be 12 volts? when i turn the key i cant hear the fuel pump come on... all my fues are good? can anyone give me some information?
RE: fuel pump NEED help!!!
The pump is either bad and drawing too much current, this will cause a voltage drop, but should also blow a fuse. Also possible that you have a high resistance connection (dirty or corroded connectors, bad relay contacts, etc..) that is preventing the full current to get to the pump and causing a voltage drop.
johnson3034
05-25-2007 09:35 PM
