fuel injection
i have a 86 camaro 2.8 mpfi the probem is inectors on left side not working with power on car not runningall 4 wires at harness getting power used noid not flashing on left side replaced module in dist, still no pulse on left side i think its ecm any suggestions on how to test
Unplug the wires from a bad injector & check that one of the wires has 12 volts to ground. If not the fuse is blown or the lead broken. The fuses should be be in the fuse block in instrument panel. There are 2 fuses, one per bank.
i have also put left side injecters in right side has no problems running with those injecters, i do not think its my injecters i think its ecm or short somewhere even when i switched injecters from left to right still only runs on right side left side not pulsing the only ground that would control them is the ecm its self on wiring dia, it showes injecter switch for left and rightplus a ground symble inside ecm
