engine upgrade
engine upgrade
i will be putting in a chevy 350 4 bolt main or 327 with a 4speed manual trannyinto my 96 camaro to get rid of the v6 5speed and was wondering if there was anything special i needed to do to it? will the shifter be mounted in the same spot or will i have to move it back or forward at all? i will probably need a cowl hood to be able to fit the engine in there wouldnt i? please help me out with this give me some opinions alright thanks laterz
RE: engine upgrade
since the engine is more than halfway underneath the dash, clearance will be a huge issue...something that might not be an 'easy' fix w/ a cowl hood
anyways, it's all going to be custom so good ****in luck!!! but it will be sweet if you do so
lonso916
08-25-2007 10:42 PM
