engine died ! wont re-start
RE: engine died ! wont re-start
Also, a "crank but no start" condition may also come from the oil pressure switch, or the fuel pump relay,(or its fuse). Just some other bastardly problems, that might be the cause. good luck.
well all fixed! it was the electronic ignition control module, took about 5 minutes to slap it in! and she fired right off! seems to run just fine, i realy appreciate all the help in diagnosing the problem and you responded fast too, cause i needed that car for work tonight! again thank you all, i lve this forum take care all, cya around the forum[sm=closed.gif]
