EGR and HEI?
RE: EGR and HEI?
HEI is High Energy Ignition distributor. EGR wasn't found on a Camaro until 1982. EGR stands for Exhaust Gas Regulation. You can also buy block off plates to remove it and gain m ore horsepower.
RE: EGR and HEI?
Guys, here is the point:
I'm secting parts for my project a Camaro 74 - 75. Searching in edelbrock's site thety list a lto fo models of intake manifold. Someone have the EGR another doesn't. So it's the same thing with ignition, here i'll use MSD system but i needto know if this model of Camaro have HEI ignition because i have to select the right distributor. I'm waiting the reply from MSD.
Thanks for all, Marcelo
RE: EGR and HEI?
You have a V8? If you do not have emissions where you live you can get a non egr. If you do you need to check your areas regulations. Any small block distributer will work. There were few exceptions for a small block chevy but you should not have one of them.
RE: EGR and HEI?
Well guys,
i want to haveoneV8 350 in a 74 -75 Camaro. I wrote to Edelbrock and the parts sellectare:
1 - Intake manifold Performer RPMEPS idle - 5500: #2701
2 - Cylinder heads Performer RPM: #60899
3 - Camshaft kit: #2103
From MSD, i still waiting the reply. But when we talk about carburator i'll use a Holley 670cfm withavacuum 2nd and manualchoke. Aboutthis last iten what do you thinkabout it?
Thanks MArcelo
Thanks MArcelo
