Distribtor
RE: Distribtor
after you remove the cover and the wires just unplug it from the wiring harness then you use a distributor wrench size 9/16 to remove the hold down on the passenger side of the distributor on the intake and once you remove that it should just slide out but don't forget to mark were the rotor button is pointing
