diagnostic codes
diagnostic codes
Has anyone check the diagnostic on their 02 model camaros? When I tried the security light did not flash like I thought it was supose to and there was no tones. I am not using a diagnostic equipment only the diagnostic check where you take the fuse out for the radio and turn the ignition on and off a couple times, I wrote down the exact procedure dont remember it at the current moment. So any suggestions??
RE: diagnostic codes
Most ODBII cars have to be scanned to read codes. If you intend to do your own work, you should invest in a ODBII scan tool, or at least a code reader. Auto Xray makes a reasonably priced scan tool that does averything except ABS & Traction control.
apacheco514
03-03-2011 10:47 PM
