Consuming Oil
Old Apr 28, 2008 | 06:04 PM
  #21
Slick6's Avatar
Default RE: Consuming Oil
Will I be ok with water for a day or so?
Old Apr 28, 2008 | 06:05 PM
  #22
SpecterGT260's Avatar
Ninja Administrator
i wouldnt, just because tap water will cause rust fast. the coolant prevents this
Old Apr 28, 2008 | 06:08 PM
  #23
MusicMan's Avatar
The Jazz Man
yeah, you should be, unless it gets cold at night. You need to get coolant in asap, If you can't find dexcool at the local auto store, high tale it to the nearest dealership.
Old Apr 28, 2008 | 06:13 PM
  #24
Slick6's Avatar
Ok, straight dexcool or mix with water?
Old Apr 28, 2008 | 06:15 PM
  #25
Ninja Administrator
mix it. i jsut have 1 gallon jug of it in my radiator, poured straight in, then ran it and kept topping it off with water. but i drained my whole system during the cam swap.
  #26
MusicMan's Avatar
The Jazz Man
I believe it's a mix, but ask them while you're there getting it. I don't know if it's 50/50 or not.
Old Apr 28, 2008 | 06:27 PM
  #27
Slick6's Avatar
Thanks guys.
Old Apr 28, 2008 | 06:44 PM
  #28
Slick6's Avatar
FYI It's 50/50. 1.5Gal of DexCool and 1.5 Water should fill it for any curious minds.
  #29
Slick6's Avatar
....and does it need bled when I fill it?
