Carb Tuning
Old Oct 15, 2019 | 10:56 PM
67Cuda408's Avatar
Default Carb Tuning
I have a 408 small block with a vacuum secondary Holley with two corner idle adjustment. I have hooked up a vacuum gauge to adjust for best idle and I get it at 1/2 turn from bottomed out. Does this seem right? Idk why it seems like this can’t be optimal. Thanks for any help.
Old Oct 16, 2019 | 06:50 PM
Everett#2390's Avatar
Your symptom is because the primary plates aree further open than normal and allowing fuel from the main circuit rather than the idle circuit.
On the carb, pass side on the base plate is an adjustment screw for opening the secondary plates for air bypass, so the primary plates can be closed allowing the idle circuit to work as normal.
You can open and hold secondary plates full and measure height of the screw, as the slot is on the underside and carb removal is required for screwing 'in' the screw opening the secondary plates.
You can place a feeler gauge between the screw top and arm and add thickness to the measured distance, make primary adjustments, both idle speed and needle, for best results, then remove carb and adjust screw height, measured height and add feeler gauge thickness, and repeat process from there.
Also, placing manifold vacuum on distributor vacuum advance for advancing initial timing for better vacuum reading.
The more vacuum the better.
Chrisd0729
Nov 18, 2012 05:59 PM
Cory Apple
Mar 28, 2012 11:59 AM
maskedman
Jul 12, 2009 11:27 PM
n269nando
Jul 20, 2007 12:22 PM
