Camaro window problems
Hi, I have a 97 Camaro and am having window troubles with it. The motors seem o.k. but the windows only go part way down and stop or they go clear down and can't get them to go back up. Is it the switch or could it be the track? How would I go about fixing this?
Do they start to work again after a few minutes? It sounds like maybe the motor overload protection is causing them to stop. If you have a mulitmeter, you can remove the switch and ohm them out to see if they are working. Usually, this is a symptom of motor going bad.
