Camaro Code Reader.
Old 07-25-2011, 07:22 PM
krazymonkeys's Avatar
It's been a number of years but it seems like this was it. I do know the one I bought was made by another company, maybe out of business, not sure. There isn't a link on the advance website but if you look in the section with all the "Help!" parts like in the link you should be able to find it. NEW HELP! HELP 47007 EGR CLEAN SCREEN GASKETS QTY: 2 | eBay
Old 07-26-2011, 01:34 PM
94ChevyCamaroV6's Avatar
Well that may keep all the chunks out but where will the chunks end up going to If they are screaned out.
Old 07-27-2011, 03:05 PM
I would think they would break up on their own. Those chunks aren't very hard they break up easily. It's just that the spring on the button is very weak to allow nothing more than increased suction during high vacuum to open. This makes it so that the egr valve can't break the chunks up on it's own. By keeping them from going in you prevent the rough idling the chunks cause when they are holding the egr valve open. The egr valve only opens during high vacuum which limits it mainly to low rpms but if it is held open the PCM will alter fuel and airflow to the numbers you would see during high vacuum causing a rough idle at different rpms than what the egr valve being that far open would generally mean to the pcm.
Old 09-15-2011, 11:46 PM
kawidirtrider's Avatar
Any code reader should report any codes that are being pulled simultaneously. My camaro was running just fine for the last 10 yrs then my 17 yr old drives it for 4 weeks (right after I had interior/exterior detailed for $280.00) anyway and all kinds of stuff is goin on i pulled mis-fve-ccm-cat-eva-025-htr-egr-PO305 PO102, I knew the gas cap was left off which was the eva code so i replaced that and retested and all the other ones disappeared leaving me with only a PO102 So at first glance I thought what the then baam not so bad. Auto Zone has a pretty good one for $89.95
hevymetalg
10-14-2008 12:08 AM
hevymetalg
09-28-2008 07:50 PM
jfresh
09-01-2008 06:44 PM
350rs
07-12-2007 03:50 PM
Celticsfan
05-26-2007 02:23 PM
Quick Reply: Camaro Code Reader.
