broken pushrod
Old Nov 13, 2006 | 12:06 AM
hotrodguy1986's Avatar
Default broken pushrod
i have a problem, my 1977 camaro lt broke one of its pushrods. it started as a lite tap so i pulled the valve covers and noticed two rocker arms loose and one was missing the push rod all togther so i pull the intake and find two lifters laying in the galley and half a pushrod i can't seem to find the rest of it. is it possible for it to make it to the oilpan with out coming in contact with the crank or rods because i didn't here anything but that tapping also if the cam broke it do you think it damaged the cam some advice would be appreciated
Old Nov 13, 2006 | 12:09 AM
shnormo's Avatar
Default RE: broken pushrod
It is very possible that the pushrods could've gone into the pan through the lifter gally drain holes. As far as coming in contact with the crank, it is always a possibility. The cam could have caused the damage. I would take the oil filter off and cut it open to see what is inisde it.
Old Nov 13, 2006 | 12:17 AM
i will probably try that if i do have to pull the oil pan does the motor have to be lifted or do you think it will clear the crossmember
Old Nov 13, 2006 | 02:12 AM
shnormo's Avatar
It'll have to be lifted.
RamzaFreak20
Oct 17, 2011 01:02 PM
3.4_V6_Maroboy
Sep 20, 2009 09:42 PM
92lxsleeper
Aug 26, 2008 10:40 AM
jxdesign
Feb 11, 2007 03:13 PM
gotalcoholmanup
Jun 28, 2006 02:29 AM
