-   General Tech (https://camaroforums.com/forum/general-tech-5/)
-   -   brakes (https://camaroforums.com/forum/general-tech-5/brakes-13426/)
Koryn Apr 21, 2007 04:37 AM
brakes
i have a 2001 camaro. i need new brakes in the front and i was wondering if C5 vette brakes would work? anyone know if this is possible? thanks
Koryn Apr 21, 2007 06:17 PM
RE: brakes
well ive managed to find out what you need is a caliper mounting bracket. however if anyone knows where i might be able to find this that would help as baer wants to charge $500 becuase they figured out that iam not buying their $1300brake kit. but man what a rip off 500 for a bracket. thanks
cplthomas Apr 21, 2007 06:25 PM
RE: brakes
Are you trying to upgrade your brake system or just replace worn pads/shoes?
Koryn Apr 23, 2007 05:40 AM
RE: brakes
iam trying to upgrade my stock calipers and rotors with one from a C5vette. i found out there is a braket i need in order to mount up the calipers from the vette. what iam not sure on is if i need the whole hub assembly with the bearing or if the just the bracket will work. Also iam not sure where to find the bracket cause iam not payin $500 for one either. thanks
