bolt broke on my heads HELP!!!!!
RE: bolt broke on my heads HELP!!!!!
if thats the case. grind the top of the broken bolt flat, use a punch to put a point in the center, get a left handed cutting drill and drill it out. if the bolt started to come out before it broke the drill will usually just back it out the rest of the way. if it didn't move then you will still have a starter hole to put an easyout in to get it out
Just keep in mind that headbolts are made of pretty tough material, so get a good supply of drill bits. May want to go to a machine shop supplier and pick up some solid carbide bits.
bolt must have been in a water jacket and has serious corrosion on the tip or was seriously crossthreaded. if thats the case you'll be lucky to get it out with an ez. if all alse fails ... slowly and careful drill to one below the diameter of the bolt then tap the remaining thread material out with a sharp pointed awl. sick
You Guys have never heard of a broken head bolt ? C'mon it happens all the time. I've removed literally hundreds of them over the years. Be very careful not to touch the threads in the block when You drill it. If You do screw up the threads, You can but a Helicoil kit to fix that problem. It's a 7/16 coarse thread bolt ( USS thread Not SAE ). Replace all of the head bolts because if one has broken then the others can follow suit. Fel Pro and Pioneer sell head bolts. ARP sell a much better than stock head bolt kit. I always use them in performance engines.
ORIGINAL: z28pete
the thing is that carbide has NO give and can chip and get lodged into the part. Cobalt gives and doesn't really chip. when you are doing things by hand without the steadiness of a quill or the even pressure of a machine, Cobalt is the way to go
LUVSSUNSHINE76
07-05-2010 03:29 PM
