Battery drain
Old Apr 7, 2006 | 02:35 AM
Tom97V6's Avatar
Default Battery drain
I have a 97 v6 camaro and when i was driving it i went to turn on the ac and the car went black and shut off. I pushed it to the side of the road and cheked the voltage the battery was giving me and it said it was like 6 or 7 volts, i removed the positive terminal and it reset itself and worked, but similar things have happened since then. Also the spedomiter shot up to over 120 even though i was not moving Is there some shut off built in that resets. The battery is new and the conection is good thank you for any help
Old Apr 7, 2006 | 05:32 PM
imperial's Avatar
Default RE: Battery drain
make sure the surface of it is clean.. you can clean it with baking soda + water... and check the terminals if its a maintenance free battery
Old Apr 7, 2006 | 06:40 PM
94Z28SHAKER's Avatar
yo, same thing happened with my grand prix, after about a month of haywire gauges and shutting off all of a sudden, it turned out to be the alternator. it costed about 75 bucks with a core return.
BZpbp
Nov 7, 2012 09:22 AM
frmjersey
Feb 12, 2009 05:29 PM
jpucci
Aug 19, 2007 08:56 PM
jpucci
Jul 17, 2007 09:54 PM
86 camaro
Jun 8, 2007 01:28 AM
