Air Cleaner...?
I was lookin over different styles of air cleaners because I just want somthing different for every other standard air filter out there and I came across this...
http://static.summitracing.com/globa...e/edl-1002.jpg I was just wondering... how do these work? Do they allow better airflow? How do they attach to the carb? Ect ect ect... Thanks |
RE: Air Cleaner...?
Its a washable wide open foam filter.You will get all the cfm your carb will take. There is a stud with a lock nut and it replaces the stud on your carb then the base bolts to it. I have a brand new one still in the box I will sell you.
RE: Air Cleaner...?
How much? Does it have the foam insert?
RE: Air Cleaner...?
Yes it has the foam filter,but no don't get it. I have one and the foam falls apart easy and falls into the carb. The only reason I have one is hood clearance. it crushes when I close the hood, stupid big block. get the K&N or the holley version , I think it's blue. .........Oh yeah, I've only had the filter for 4 months if that helps to how long the filter lasts.
RE: Air Cleaner...?
yeah i had that same edlebrock on too....they suck
RE: Air Cleaner...?
Well thanks for ruining my sale you F#$%^ng A@$$&^es:D
RE: Air Cleaner...?
Oops sorry..........um, yeah...the one madmike has is made with a special filter that seems to add 20 to 30 hp, combine that with one of Z28pete's gutted cats and your lookin at a 300 hp gain. Hope that helps out.:D
RE: Air Cleaner...?
id buy it and look into a no toil filter element, and custom fit one from a motorcycle. those things last for years through dirt and such, just gotta make sure you wash and oil it
RE: Air Cleaner...?
ORIGINAL: 74454bb Oops sorry..........um, yeah...the one madmike has is made with a special filter that seems to add 20 to 30 hp, combine that with one of Z28pete's gutted cats and your lookin at a 300 hp gain. Hope that helps out.:D Hey I have a cat here I can gut also. Its a viper killing cat! |
RE: Air Cleaner...?
LMFAO! right.... I'll take 6 of those CATs :D
