89 Camaro wont start
I have a 89 rs camaro with a 2.8l v6 mpfi and i just replaced the fuel pump because it did not provide presser and would not hold now that the new ones in i cant start my car and after i try to and turn off my car my fuel pump makes a lot of nosies i tested the new pump and it shows 47 psi and slowly drops. plz i need some trouble shooting ideas.
I think you may have put in your pump upside down
Can you hear the pump running when you put the key in and turn it to the run position?
yes i can
How would it be upside down
Check to see if you are getting fuel to the fuel rail by pressing on the bleeder valve on the rail. If none comes out, you might need to replace the filter. I would post this in the 3rd generation area and maybe get quicker replies from people who have replaced the pump on your model.
ok i will and i have done that and gas is commin out if it but not every ime is that a problem?
Originally Posted by No1chixmagnet
(Post 431581)
i have checked them all ready
| All times are GMT -5. The time now is 03:43 AM. |
