89 Camaro wont start
Old Jun 14, 2010 | 03:57 PM
No1chixmagnet's Avatar
Exclamation 89 Camaro wont start
I have a 89 rs camaro with a 2.8l v6 mpfi and i just replaced the fuel pump because it did not provide presser and would not hold now that the new ones in i cant start my car and after i try to and turn off my car my fuel pump makes a lot of nosies i tested the new pump and it shows 47 psi and slowly drops. plz i need some trouble shooting ideas.
Old Jun 14, 2010 | 04:03 PM
CAMDriv3r89's Avatar
I think you may have put in your pump upside down
Old Jun 14, 2010 | 04:07 PM
osduck5's Avatar
Can you hear the pump running when you put the key in and turn it to the run position?
Old Jun 14, 2010 | 04:17 PM
yes i can
Old Jun 14, 2010 | 04:22 PM
How would it be upside down
Old Jun 14, 2010 | 04:34 PM
osduck5's Avatar
Check to see if you are getting fuel to the fuel rail by pressing on the bleeder valve on the rail. If none comes out, you might need to replace the filter. I would post this in the 3rd generation area and maybe get quicker replies from people who have replaced the pump on your model.
Old Jun 14, 2010 | 04:37 PM
ok i will and i have done that and gas is commin out if it but not every ime is that a problem?
Old Jun 14, 2010 | 06:27 PM
osduck5's Avatar
You should get gas out of the bleeder valve every time you turn the key to the run position and hear the pump running. It should pressurize the system. If not, you might want to check at the fuel filter and see if gas is pumping through it. Did you change it when you changed pump?
Old Jun 15, 2010 | 07:45 PM
i have checked them all ready
warmeck
Jul 3, 2014 10:34 PM
Scott Blankenship
Apr 2, 2013 10:09 AM
BrandNew
Aug 1, 2008 08:15 PM
Jims94LT1
Aug 27, 2007 08:37 PM
