81 z28 4 spd, starter question...
Hey guys, I'm currently restoring a 1981 Z28... It started life as a 350, AT car, and since then has been converted to a mid 80's 350 4 bolt main, with a Saginaw 4 speed transmission, probably mid 70's, and I believe that it has the older smaller sized clutch and bellhousing on it, I'm thinking 10-10.5" maybe?... My question is, what starter do I use on this guy?... My AT starter didn't work, so I got a MT starter, that according to Oreilly Auto Parts fits all Camaro's with MT from 70-81... There does seem to be a different number for 69, should I try that one?... Does anyone happen to know which one I need?...
Thanks for your time fellas... |
You have a duplicate thread in the transmission section:
153 tooth flywheel-straight mount starter. 168 tooth flywheel-angled mount starter. Just make sure the starter you get is for the same vintage fitment your flywheel is. |
