69 camaro frame motor mounts
Hello
Can you guys tell if the motor mounts on the frame are the same for big block an small block? is there a difference? between the both.?or can use the same ones for small block? thank you your effort is greatly appreicated. |
RE: 69 camaro frame motor mounts
Yes, they're different. The big block Mounts kick the engine forward a bit for distributor clearance.
yes there different, but the big block dont kick it forward
in order to gain engine compartment clearance the engine was offset 1 inch to the right (towards the passenger side) by means of asymmetric brackets. check out this site it gives the differences http://www.camaros.org/engine.shtml#EngineMounting |
