68 camaro starting troubles!!
Old Jun 21, 2008 | 08:55 AM
rb26skyline99's Avatar
Default 68 camaro starting troubles!!
its about time me and my dad tried starting up the camaro ts been sitting for a while we rreplaced the battery and it works fine winshield wipers headlights are working fine... but we gave it a shot at staarting it but the camaro wasnt turning over at all any1 got any suggestions on whta i should change or what i can do to get this thing started please and thank you
[IMG]local://upfiles/13613/C47F22F088B7400FA80EA50B223BD7B9.jpg[/IMG]
Old Jun 21, 2008 | 09:18 AM
Default RE: 68 camaro starting troubles!!
Holy shizz, how long has it been sitting? If you can hear the starter trying to work, but nothing moves, the engine could be frozen in place. Remove the spark plugs, squirt a bit of penetrating oil into the plug holes, and try to rotate the engine over by hand.It should turn over freely, otherwise you could have rust inside locking the rings to the cylinders. If you get it freed up, you might be lucky and not have to do any internal repairs. If it already turns over ok before soaking it, then your starter may be bad.
Old Jun 21, 2008 | 07:30 PM
dd442's Avatar
The starter could most likely be looked up also, you counld try tapping it with a hammer but that might not work all the time, First try turning it over by hand first like he said if it does the go straight to the starter.
Old Jun 22, 2008 | 12:43 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
X2 on turning it by hand and the penetrating oil hint. If you can turn it over by hand IE; grabbing a hold of the belt or putting a sockett on the flywheel and turning/rotating than you might have a bad starter or somethinig alse electronically related. Also it help to remove all the plugs before rotating by hand - you dont have to fight the preassure in the cylinders.
Old Jun 23, 2008 | 11:07 AM
THANK YOU EVERYONE!!! ITS TURNING OVER NOW JUST FINE IM JUST ME AND MY DAD ARE JUST GONNA JUMP START IT SEE IF THT WORKS SINCE HE TOLD ME THE BATTERY WAS OUT OF HIS TRUCK NOT NEW-_-
Old Jun 23, 2008 | 11:11 AM
02StanGT's Avatar
Any more pics of it? Plans for it?
Derek Tackett
Feb 17, 2014 02:30 PM
hb22man
May 20, 2010 08:37 AM
brizee
Feb 8, 2009 08:03 PM
bmeister2
Jan 16, 2007 05:00 PM
molamann
Aug 15, 2006 02:10 AM
