-   General Tech (https://camaroforums.com/forum/general-tech-5/)
-   -   67 rs headlight motor question (https://camaroforums.com/forum/general-tech-5/67-rs-headlight-motor-question-57951/)
bbar Dec 31, 2010 07:10 PM
Hi,
Have a 67 RS. Pass. side headlight motor has stopped working. All relays, limit switches , etc. are okay. Need to test motor. Pigtail from motor is 2 wires. Do I remember right that you hook up 12 volts to it and it should go 1 direction hooked up one way, and one direction hooked up the other? I'm betting the motor is froze since I'm seeing grease leaked out on the bottom of the motorplate. These are repro motors I put in when I built car 14 years ago. Thanks
Bandit63 Jan 2, 2011 06:45 PM
That would be correct.
