1999 SS CAMARO NEED ADVICE
I have a 1999 SS Camaro that has 143,000 miles and is now in need of some help in the form of advice.What are the best spark plugs touse and also I am in need of 1 ea. chrome rim that was an upgrade for the 1999SS Camaro. I have onethat has a leak around thebead and I put air in it about every 3-4 days but discount tire cannot seem to fix it. Does anyone have a diagram or kind of print so that if I decided to fix the ascending unit in the gas tank, Icould cut the floor out in the area where the ascending unit is located instead of dropping the tank to fix it????? Thanks for your time, JT
[IMG]local://upfiles/15556/CAA8CB3291B549A49E8567F6E2F4BF3D.jpg[/IMG]
What do you mean its slowly dieing ? Have you had a compression test on the cylinders ?
Plugs you should go with A/C delco, they are good and not expensive at all.You can go with some magnaflow high flow cats i think they are like $100 a piece im not sure exactly.Doesnt seem like its in that bad shape, so i wouldnt sell it just yet.
1981camaroz28
Oct 23, 2007 05:44 PM
