1969 Camaro won't start
Old May 9, 2022 | 04:12 PM
SeanMcfarland's Avatar
Default 1969 Camaro won't start
Hello all, I have a 1969 Camaro SS 396, when i go to start the car it will start and stay started long as i keep the key turned to start, soon as i release it to run position it will stall. I have a MSD Distributer so the coil and everything is in the distributer. I was thinking resistor but not sure if it has one with the MSD dist? Any help woud be great Thanks Sean
Old May 9, 2022 | 07:36 PM
Sounds like you have a wire hooked up wrong.
Old May 10, 2022 | 04:58 PM
I think its my starter switch, anyone know how to replace a starter switch? Im going to search the site now. Sean
Old May 12, 2022 | 08:21 PM
Replace and checked starter switch and still have the same problem
Old May 13, 2022 | 06:10 AM
Everett#2390's Avatar
Go back to OE configuration and enjoy the continuous running.
May need a cleaning of ign switch contacts mounted on top of steering column above pedals. Use contact cleaner and rotate key cylinder while spraying/cleaning.
Remove positve battery cable first
Old May 22, 2022 | 11:03 PM
The original coil had 2 power wires. The start wire, which is working, and the second one was a key on resistance wire. Make sure that second wire has voltage when the key is in the run position. You may need to run a new wire if that one is dead, or if it is still a resistor wire. Updated electronic ignitions want a full 12 volt supply, not resistance voltage.
daughterjudy
Jan 24, 2011 06:09 PM
ricks1969camaro
Jan 2, 2010 11:02 PM
neversave
82-92 V6 Tech
Feb 4, 2009 11:59 PM
Z28Reggie
Dec 1, 2008 07:39 PM
BrandNew
Aug 1, 2008 08:15 PM
