04 durago pp441
Old 08-29-2007, 08:00 AM
bluovlh8er's Avatar
Default 04 durago pp441
check motor light says pp442, where to start?
Old 08-29-2007, 08:50 AM
ghotachevy's Avatar
Default RE: 04 durago pp441
It's a problem with your EVAP emissions system. It could be as simple as a loose gas cap or broken vacuum line...or as serious as a bad solenoid or charcoal canister. I'm not familiar with the system the 3rd gens use though, so I can't say which it is for sure.
You can find a download link for a service manual for your truck here: http://www.dodgeforum.com/m_481986/tm.htm
You can use the info from it to check the lines on your truck for leaks/cracks. Good luck! [/align]
Old 08-29-2007, 09:02 AM
bluovlh8er's Avatar
thanks for the effort man. above and beond
Old 08-29-2007, 12:46 PM
SpecterGT260's Avatar
Ninja Administrator
i was just going to tell him to RTFM [&o]
