Woo Hoo eventually pulled a 12 seconder
Well, after the weekend at the drag strip I was really gutted on the first day when after LS6 intake, 3" true duals, LT headers and a bit of EFIlive tunnning I only got a 13.12 after my previous best of 13.24 (albit on a different track)
Anyways, on the second day and after lowering my spark table (stock 99 z28 is well advanced and runs rich) i pulled a 12 sec pass on my second run, and with street tires and a poo 0-60ft time Here is it: 0-60ft : 2.0437 1/8 ET : 8.4299 1/8 MPH : 84.72 1/4 ET : 12.9718 1/4 MPH : 106.58 This track is not the best in the UK, I had to set off on 50% throttle to get best launch, and also the 1/8 times and MPH values as different depending on right or left side of track, RH side is always about 4 mph faster than left, on same ET at 1/8 and 1/4 But still pulled a 12, just, and was running 13 flat all day, could have got another couple of 12s I think but was in bracket series and had to back off so I didn't break out |
GOOD DEAL MAUDY!!!! Thats awesome dude. 12's and still with stock gears of 273 also??!!! Now i really really wanna go to san antonio to run my car, but wanna put headers on first. Now i wonder what mine will run????
Originally Posted by maudyZ28
(Post 428916)
ss_2000, dude im sure you'll easily get into 12 with the 3.73s, providing you can get power down. I tried a ball out launch at full throttle after the green and it just spun up all the way to 2nd, got a 14.5 on that run hahah :) Yeah still 2.73 gears and have to lauch at 50% throttle
kissmytush, well the stock pcm parameters command 11.7 : 1 fuel ratio, but optimum is more around 13:1 to 12:1, so I set mine at 12.6 (dont know how accurate it is exactly as i dont have a wide band yet) but I check with a 2002 camaro tune and that runs about 12.5 ish so i cant be that far out. PLus most tuners say they keep the stock MAF as the calibration changes depending on this |
Well im gonna have to make plans to go sometime this summer. I know im gonna be hooked after that. Lol. :) So when you gonna do the rear end maudy???
(Post 429808)
Originally Posted by KissMyTush
(Post 429875)
Ok, I have a SLP Mass Air Flow sensor could that fix this? How do I check it to see what I am running?
SS2000, lmao, only when it breaks :D |
Lol!! I hear that maudy!! Thats why i just went ahead and did the gears and did all the bearings and seals, its all good just staying away from sticky tires!! lol.
sticky tires on stock rear end = bad ju ju lol
Good job maudy.... i told you it could be done... 12s on streets.... Awsome
