From your experience
Old Jul 28, 2009 | 03:51 PM
al3flangy's Avatar
Default From your experience
i will began my new project but i need some help before starting
i have 01' camaro ls1 engine w manual TM so i will put supercharger but before putting i want to disscus about my new part look at it below :
http://www.summitracing.com/parts/CCA-54-468-11/ (cam shaft)
http://www.summitracing.com/parts/CCA-54100/ (valvetrain kit)
http://www.summitracing.com/parts/EDL-29085/ (intake maniflod)
http://www.summitracing.com/parts/EDL-3864/ (throttle body 90 mm )
http://www.summitracing.com/parts/ACC-74620S/ (injectors 62 LPs)
http://www.summitracing.com/parts/ESP-6125O3D/ (connecting rods)
http://www.summitracing.com/parts/WIS-K392F3905/ (pistons)
until now this is all things what i decide to put ??
so if you have more ideas let me know
Old Jul 30, 2009 | 08:40 AM
z28rob18's Avatar
thats a huge cam and will need some high rpm. what crank?
Old Jul 31, 2009 | 09:06 AM
al3flangy's Avatar
stock crank .. but some ppl told me the stock crank can afford to >> 700 HP ??
so what u say ?
Old Jul 31, 2009 | 09:49 AM
z28rob18's Avatar
id say it may be able to handle that hp but idk if itd handle the 7200 rpms. if i was you id call a place like total engine airflow or just comp and have them spec you a cam that way your not usin an off the shelf cam that makes you spin the motor high as hell. but if you find the stock ls crank can handle them rpms then it all sounds good to me
Old Aug 1, 2009 | 03:26 AM
al3flangy's Avatar
hhhhhhhhhhhh it would be have loud sound
Old Aug 8, 2009 | 09:55 PM
Make sure you run that combination past the tech people at Summit to have them figure out if you'll have enough valve clearance with a cam that has that much lift! I personally would keep it down under .550 lift, and 280 duration.
The specs on that cam look great for a race vehicle, but not for one you're using for dual purpose street/strip.
chuckles
Apr 26, 2013 10:37 PM
Spartan66
82-92 V8 Tech
Feb 6, 2012 08:13 AM
100ctane
Feb 28, 2011 04:03 PM
DarlingReject
Apr 20, 2010 07:33 PM
