Winter Mods List, Suggestions Please!
The Z is getting parked here probably in the next two weeks, and in that time I'll be saving up for a few mods. I plan on pulling the engine out to address an oil leak (NEVER will I use an Ebay oil pan again.) While it's out, I plan on doing a few things. Here's the list:
Patriot Performance 185cc Vortec heads, 2.02 intake valves, assembled, .575 lift springs
Jegs .488"/.488" lift/292 duration cam and lifter set
Proform 1.6 Ratio Roller Rockers
Comp Cams High Energy Push rods
Jegs aluminum finned oil pan
Jegs 1 piece oil pan gasket
Mr. Gasket Ultra Seal gasket set
Jegs Noisy gear drive
Hedman Elite long tube headers
Currently, the engine is a 350 4-bolt with about 3000 miles on the rebuild. Forged aluminum pistons, steel crank and rods, Edelbrock Performer intake, Holley Street Avenger 670 carb, and other bolt-ons.
I'm running a 2300 RPM stall converter with my built 700R4. What adverse effects will I see by not increasing the stall speed?
In my far-from-professional opinion, I'd say it just won't be ideal. It won't drive at 100%, and you won't get the absolute greatest track times, but IMO if it bucks a tiny bit at idle, and I can't cut 1.6 60's, I don't really care. If you went with a higher stall it would improve pretty much everything, but is it enough to be worth it? I wouldn't say so...
Just my opinion!
Just my opinion!
My winter plans, put gas in the tank and drive it. Project plans are a thing of the past and for some people the projects are never ending. Just my thoughts on the subject.
I guess I should have been more specific, the engine is coming out sometime this winter for sure, I can't deal with the oil leak anymore. While it's out I'm doing performance mods that I should have done in the first place and this is my tentative list.
I'm running a .480/.480 lift comp cam with crane energizer 1.6 full roller rockers, comp beehives and comp magnum pushrods along with isky anti-pump up superlifters. It's very streetable and I was running a 2300 stall in a turbo 400 with 3.42 gears at the time. I was running an edelbrock 2101 performer intake along with a Holley 750. My compression is a little lower than I wanted at 9.2:1 but that will change soon hopefully.
What's your current compression ratio and what are you going to if you're going to change heads?
microkid
04-19-2007 06:26 PM
