what heads should i go with?
i have an 84 and it has alot of mods including a 350 transplant which i am rebuilding, i want to get the most power possible for the money, my question is should i replace my cracked double hump heads for torquer series cast iron 202 heads or zz4 corvette aluminum heads. what should i do
RE: what heads should i go with?
thanks for the input, still doing some digging on all the specs and traits of both heads. the cast iron 202 will support alot of horse but the zz4 heads have good flow for a 194 head and i will save 50 pounds with the aluminum versus the cast iron,still not sure i like both.
kuhlman187
67-69 V8 Tech
02-12-2015 08:14 AM
