so what kind of block/ heads are these?
ok people ! I'm not the trusting type, when it comes to other people's work.
so I pulled the V8 engine out of the black omen to see ,just how good the rebuilt engine was. well, when I unhook the 350 tranny from the V8 BLOCK, I found dirt. not little but a lot. NOT GOOD. when I pulled the valve cover ,I find junk there too. so it looks like a rattle can rebuild on this engine, that’s been sitting in a farmer field, out in the north 40 some where!
here my question's;
on the driver head, I clean so I could find casting numbers 1402268 with K205.
on the passenger side ,also clean to find 14022601 with K154
so to me,not matching number mean not match heads . so what heads are these?
my block number is 15010201 with J274
ok, I know the block is a 305 but what kind of 305(car/truck/ low-po/ high-po/boat anchor)?
and what year are the the block and heads?
thanks
here my question's;
thanks
OK, I checked it out .so I got 1980 to 86 305. I couldn't find anything to tell me if it a 305 from a truck or passenger(caprice) or camaro/firebird/monty . if they use the same block and heads for all of those. what so special about the F-body having a 305 back then? if nothing? then all I got is a clean boat anchor?
