sbc 350 build
Old 11-22-2011, 03:22 PM
Dcapper81's Avatar
Default sbc 350 build
Hello I was wondering if anyone here could help me with a formula for a cheap but good powered small 350. I was planning on getting a cheap short block from pepboys or ebay. Then I would get a bigger roller cam, a set of vortec heads, and a high rise intake. I have a brand new carb sitting in the garage. I believe its a 550 edlebrock.
Now these are just basic plans. Can someone please help me with the specifics on the cam and what kind of work can I get done on the heads for better performance? Also how well will the carb perform?
Working on a budget!
Thanks for any help!!
Old 11-22-2011, 04:21 PM
djs383's Avatar
Your description is way too vauge to give any sound advice. What car is it going into? Specific goals? Trans/stall convertor speed? Answers to these questions will get the ball rolling. Beware of cheap short blocks.....There are some sweet deals out there, but a lot, I repeat A LOT of junk is out there as well.
Old 11-23-2011, 02:22 AM
Dcapper81's Avatar
Well its going into a 70 camaro. Im looking for around 350 horsepower. I hear vortec heads will point me toward this direction. I've also heard of people having work done to their heads so I was wondering what that's all about. I also hear a lot about getting hot cams. I think you get them from comp cams but I really don't know what that's all about either. I mean I know the certain diameters of the cam will raise the valves different heights and durations but I don't know what people mean when they say hot or mild. Im building my first motor
Love your iroc by the way
Old 12-08-2011, 07:56 PM
bad436z28's Avatar
first of all if your only looking to get 350 horse from a 350 with vortec heads you dont need a hot cam,let me give you a little advice get a roller cam and be done with it theres no chance of error in breaking in ur cam unless u have wrong valve springs,u only need about a .450 lift cam to get you 350 horse,a new cam and new valve springs and ur gonna be rocking and rolling 350 horse is very doable.
Old 11-10-2018, 03:25 PM
ZL1CAMARO's Avatar
hey d , did you get your motor?
z28build
02-25-2013 05:10 PM
mainejohn
09-04-2010 12:02 AM
lowlife069
82-92 V8 Tech
08-16-2010 09:06 PM
Camaro_Boi69
11-09-2008 10:07 PM
mdubpb815
05-23-2008 10:12 PM
Quick Reply: sbc 350 build
