Oil Pressure sensor location
it should be directly above the oil filter, but on top of the block near the distributor, you will be ably to see it from the driver's side, this is where it should be as far as pre-1990, after that I am not sure
What does an oil pressure light mean?
We were driving about 150 miles and after climbing a steep grade our oil pressure light came on. We stopped and found a good level spot and checked the oil and it was at the right level and looked good.
Tone Detox Review
Tone Detox Review
