oil pressure issue
Old 06-07-2010, 08:09 PM
Originally Posted by craby
obviously it doesnt work to well if his pressure got worse. that is if the pressure did get worse. he did not say what the pressure was before, only that it was dropping now and didnt before.
Maybe, maybe not, crabmeister. It could be the oil he put in. His old oil may have been thicker than the 10w30 he just put in. What was in it before?
Old 06-07-2010, 08:37 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Could be a faulty oil filter as well. I'd get a cheapo from Walmart to see if the oil pressure changes.
Old 06-07-2010, 09:14 PM
mjlynch71's Avatar
Default oil pressure
Before the oil change it was 40-30 psi even after it warmed up. I think I will go to Car Quest and get a new filter and some thicker oil, what would be to thick. I thought that using a higher end Mobil filter it would be better. I think this is a bunch of crap that changing the oil would do this. The motor is getting taken out this winter but want to be able to drive it this summer. What PSI do you consider to low. Thanks, Jerod
Old 06-08-2010, 11:55 PM
Osmiumfoot's Avatar
When my daughter's Supra starting killing mosquitoes in a 10 block radius and after the fire dept had made several responses to false alarms, I stuck some Restore in her engine and it flat-out cured it. It was amazing. So I had a 350 that was dying from a dose of cam metal and I tried Restore on it and my oil pressure went from 40 psi to less than 5 psi in a matter of 15 miles. I dumped it as soon as I got home.
Old 06-09-2010, 12:04 AM
mjlynch71's Avatar
That is what it is doing 12-15 miles then down to 7psi. Looks like I will be changing it to 15w40. Thanks for all of the input. Thanks, Jerod
Old 06-13-2010, 09:48 PM
mjlynch71's Avatar
I changed it to 15w40 and a car quest oil filter. The Mobile one was about 2 inches shorter than the new one. The new one was like the orginal 6 inch tall. I was told by some that it could have been the oil filter causing the problem. But the perssure is now what is was before 40 going down the road, and 12 at idle. Thanks, Jerod
Old 06-22-2010, 02:44 AM
msmaro's Avatar
Banned
does anybody know where I can get an oil pump for my 02 v6 camaro. my oil pressures dips very low and the oil leaks out.
Camambro
82-92 V8 Tech
04-15-2012 12:47 AM
92elder
06-04-2011 10:42 PM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
Massey
07-16-2010 11:32 PM
l3loodred
10-22-2009 10:00 AM
Quick Reply: oil pressure issue
