numbers
i dont have the opportunity to get my car dynoed so i was wondering if any one oculd tell me the est hp and tq. the motor is a 468 with a holley 750, edlebrock streetmaster intake, ported cast iron heads with 2.30 intake and 1.88 exhaust vales. the cam is a comp cams magnum 280H lift is 526. 526. 230 230 at .50. centerline is 106 and lobe separation is 110. the pistons are keith black hyperutetic domed (not sure of the cc's), hooker super comp headers, mallory billet distributor, mallory promaster coil, mallory hyfire ignition,
thanks |
RE: numbers
if you had a quarter mile time and the weight of your vehicle you could get a ball park figure here ... http://www.dsm.org/tools/calchp.htm . Sick
RE: numbers
sry i was in a rush when i posted that and when posted it and left out a few things because i was going to be late for work. the vales are actualy 2.25 1.88, it has roller rockers, and the compression is 10.5:1 hope that helps a little if you wanna know somthin else just ask
thanks |
| All times are GMT -5. The time now is 08:32 AM. |
