Newest Bullit pics
Eagle 6" h beam rod, eagle forged internally balanced crank, Probe flat top pistons, melling select oil pump, block is 1/2 hard blocked, bored 30 over, studded, line honed, decked to 9.010,balanced. 6" balancer sfi, studded, hurricane intake, dart iron eagle platinum 64 cc/ 230 cc heads, comp promagnum 1.6 rockers, 80 wall pushrods 150 over, msd pro dist, crane fireball 2 stage box. crane fireball coil. Crane solid cam(started to run out of $) 780 holley. My best guess at this point is cost is $4800 it is 11.6:1 compression it should make 550 hp at 6000 rpm.
Timmy those valve covers you have do the tops unbolt? it looks like there may be bolts in the picture, Just wondering it would make the valve adjustment easyer. Thanks
