Newbee engine swap question
Hey guys..... I just bought my brothers 97 v6 camaro with about 180k miles on it.... I wanted to swap out The motor with a 98 3800 engine..... Is this possible?? What are their any major differences that I need to be concerned about??? Thanks in advance
My question was more along the lines of differences in the engine.... As far as placement and size demision.... For instance is the starter located on the lower driverside region of the engine or is it placed in another area such as inside the motor under the fuel injection lines....
I don't know but I have just the opposite problem. I have a 98 with a bad motor and am looking at a 97 engine that is for sale. The engines look the same except the harmaonic balancer on the front of the engine and a few more shields around the manifold and starter on the 98. I have noticed in ads that the seller list the engine as a "K" engine but list them 95 thru 97 and 98 thru 02. Are they different or do they list them that way because the body style is a little different?
Finally found the link I was looking for! Hopefully this helps you. I have ask this question before but could not find the link.
https://camaroforums.com/forum/showt...ht=engine+swap
