new heads.
RE: new heads.
ORIGINAL: 95slvrZ28
AFR 180cc LT1 heads with a 65cc combustion chamber should get them to 9.1:1, but the heads have a 3/4" head decking so if you're planning on running a blower they'll be great.
RE: new heads.
You wouldn't necessarily have to lower you compression for anything, it just depends on how much boost you plan on pushing, but to be on the safe side, more for the rest of the engines sake, I'd say yes you'd still need to lower your compression if you plan on running anything over 6 or 7 lbs of boost.
kuhlman187
67-69 V8 Tech
02-12-2015 08:14 AM
