need help identifying this engine plz.
Old May 13, 2007 | 01:58 PM
sapperford's Avatar
Default need help identifying this engine plz.
alright here's the numbers that i've found on the engine.
the partial vins, well there's two of them stamped ontop of one another...the larger font one is listed first
partial vins:
VO 16T3F
C8F4 46954
the casting number:
3970010
I also found D129 stamped across from the casting number.
Also where the casting number and the D129 is stamped on the left and right side of the same piece there is 7 and S one on each side with the GM logo on the left side.
behind the timing cover and gear set I found 010 and G28 and on the back of the motor I found 010 and H15
Does anyone know what/where this piece came from?
Old May 13, 2007 | 02:25 PM
74454bb's Avatar
May 2007 ROTM
Default RE: need help identifying this engine plz.
check your other multiple post.
RichTJ99
Jan 17, 2012 10:54 PM
Mr._NeedHelp
Jan 2, 2011 11:59 AM
jh23job
Aug 10, 2009 07:25 AM
Axel
Apr 29, 2008 12:05 AM
sapperford
May 13, 2007 02:24 PM
