Need help badly
Old Apr 2, 2008 | 05:31 PM
camaro4life's Avatar
Default Need help badly
Any Help? i have a 01 ss. i just put on slp heads a new camshaft and an 80mm throttle body and intake manifold. The people running the dyno told me my car should be putting over 500+ hp to the rear with all the extras i have as well. I have the bigger injectors, cold air intake and headers with 3" pipe all the way down. It boggs and it barely holds idle. can someone give me some ideas on what is going on? thanks
Old Apr 2, 2008 | 05:32 PM
02StanGT's Avatar
Default RE: Need help badly
Did you tune the PCM?
Old Apr 2, 2008 | 05:35 PM
PCM? i told them to tune it and i even sent them exactly what i had done to it.
Old Apr 2, 2008 | 05:38 PM
02StanGT's Avatar
PCM = Your car's brains (aka the computer). Did you you send your PCM in to be tuned or was the dyno shop supposed to do it? Who installed all the parts?
Old Apr 2, 2008 | 05:40 PM
no i didnt. i have a mechanic install the parts and a speed shop dynoed the car. no one said anything about taking the computer out and sending it anywhere
Old Apr 2, 2008 | 05:45 PM
02StanGT's Avatar
You don't have to ship it anywhere. I was just asking if you did. You should have the dyno shop tune it, if it hasn't been tuned with all those mods.
Old Apr 2, 2008 | 05:48 PM
It was dynoed once. i really dont want to do it again. i guess if i have to i will. o well.if you think of anything else let me know. thanks for the advice. i do appreciate it.
Old Apr 2, 2008 | 05:55 PM
02StanGT's Avatar
Dyno and dyno tune are two different things. What it sounds like they did was run it on the dyno just to get horsepower and torque specs. If they dyno tune it, they will run it on the dyno, get the info they need to adjust to your mods, so your car will run better and more powerful. Hell, I bet it would run alot better if they just tuned your computer for the bigger injectors.The bigger injectors are dumping more fuel in the car, because the computer still thinks you have stock injectors.
Hopefully someone will chime in and correct me if I'm wrong about anything.
Old Apr 2, 2008 | 08:13 PM
35thCamaro's Avatar
ORIGINAL: 02StanGT
I'll chime in. But, you're not wrong about anything
Old Apr 2, 2008 | 08:14 PM
35thCamaro's Avatar
It sounds like your car is gonna be a beast when you get it tuned.
CheVy_R0aRrR
May 23, 2011 07:50 PM
cruz09067
Northwest
Dec 16, 2010 08:38 PM
htownguy5
Sep 24, 2009 07:26 PM
