need 383 stroker advice!!
Old 05-29-2009, 12:22 AM
chevy21's Avatar
oh and rob18 by all means i wasn't questioning your opinion about the 6" rods. I was just curious as to why the longer rod is easier on the cylinder wall. just trying to learn a thing or two :P
Old 06-07-2009, 05:13 PM
Countryboy69's Avatar
Originally Posted by chevy21
how would one go about buying the right piston?
Go forged, if your gonna boost go with a lower compression,stay away from KB hypers. Some good companies are Mahle( one of the best,very strong and light), Speed pro power forged( very good cheap piston), JE, Wiseco(has been getting better everyday), SRP.
Rod length vs stroke ratio= A longer rod will put the pivot point(wrist pin) higher in the piston, pushing it from a more centered position.
Here is one thing you definetly need to look for with a 383... Internally balanced. If you get a crank thats internally balanced you will make life so much easier for youself. Externally bal will require both a weighted flywheel and harmonic balancer. Which puts more stress on the snout and flange of the crank. The design of the 3.75 crank leaves the snout weak. The circle track builders have started using lighter balancers and that has helped as well. I was running one a couple of years ago and just knew it was gonna blow. 8150rpm at the end of the straight! With the new setup she held together quite well. It actually dropped a valve after almost a whole season. I sold it to a guy who dropped it in a 3rd gen and its still going.
Old 06-07-2009, 05:31 PM
sohcnick
03-25-2013 04:03 PM
travis t
10-29-2007 07:48 AM
1981camaroz28
10-23-2007 05:44 PM
sepadowd
08-12-2007 09:57 PM
Quick Reply: need 383 stroker advice!!
